timing belt.
Old Jan 25, 2006 | 01:49 AM
slag's Avatar
Default timing belt.
I have a 2000 gt and I was wondering if anyone had put a timing belt on theirs? I wanted to do it myself but was wondering how hard of a job this would be to do.
Old Jan 25, 2006 | 09:58 AM
Default RE: timing belt.
If its not something your comfortable doing or you are not sure how to do i would suggest just not doing it yourself, spend the little extra money to have it done right because you have to make sure that the belt is put back on with the correct timing and that you have the correct tension on the belt. The littlest mistake could easily bend some valves. Take it from me, i had to have my entire head rebuilt.
If you are going to do it yourself then just make sure you do your homework.
Old Jan 25, 2006 | 11:02 AM
eclipsed4u's Avatar
if you have very little mechanical experience, pass on this idea. its not an easy job. there is a reason the dealership charges so much in labor.....its alot of work.
Old Jan 25, 2006 | 11:07 AM
ORIGINAL: eclipsed4u
[sm=exactly.gif]
Old Jan 25, 2006 | 04:22 PM
the V6 makes it even more of a project. I would pay someone to do it cuz if its done wrong you will have an expensive rebuild on your hands since the car has 2 heads you dont want to need to pull them off to replace valves
Old Jan 26, 2006 | 01:01 AM
slag's Avatar
thanks for the help.
judien
Mar 9, 2018 03:41 PM
marx88
Jun 30, 2011 03:54 PM
8000RPMS
Aug 30, 2007 05:49 AM
agallardo
Oct 29, 2006 11:33 AM
shawnharper
Jan 31, 2005 03:30 PM
