Turn Signal Help Please
Old Feb 15, 2006 | 03:55 AM
PooT_Nation's Avatar
Default Turn Signal Help Please
Hey, ever since i bought my Eclipse GST my turn signals are weird. My left one goes slow while my right one is double the speed?
I made a small movie of what I mean.
http://media.putfile.com/My-Turn-Signals
I would like to make both the signals the same speed. would rather the slower of the two. Anyone can help?
thanks!
Old Feb 15, 2006 | 07:27 AM
Sanguinius's Avatar
Default RE: Turn Signal Help Please
This is an easy one. Turn your faster turn signal on now step outside the vehicle and go to that side. Look at the front and teh back blinkers. Is one out? Replace that bulb it should fix the problem. Most of the cars nowadays use a faster blink rate to inform you that there is a blown bulb. Keep that in mind next time you have this problem
Old Feb 15, 2006 | 10:43 PM
ORIGINAL: Sanguinius
well ****, tonight I'll go out and check it out. If that's not in I'm comming for you haha j/k
Old Feb 16, 2006 | 04:22 PM
Sanguinius's Avatar
LOL well it's either that or your blinker relay and if both sides aren't doing it that counts the relay out. Let me know if that fixes it though.
Old Feb 16, 2006 | 07:49 PM
uh oh....
I turned on the turn signals and every bulb that I can see is working. But its weird. on the back the slower signal flashes both blubs at the same time (I can see two bulbs flashing) and the right side the bulbs flash at different times. it's hard to explain w/o visuals, sorry.
but that's what i can see. [&:]
Old Feb 16, 2006 | 10:13 PM
Sanguinius's Avatar
Did you replace any bulbs recently? Sounds like one might be backwards? Also try turning on your running lights some cars actually blink faster if there is ANY problem with one of the blinker bulbs (Remember the running lights are also part of the blinker as a dual filament bulb on some cars).
Old Feb 17, 2006 | 06:32 AM
hmm, OK, I'll check that out tomorrow. I'll see if I swap the bulbs maybe they'll start blinking at the same time
[sm=signs003.gif] to me. haha. I'll figure this out. though if it takes a while, it wont kill me.
Old Feb 17, 2006 | 06:40 AM
Sanguinius's Avatar
Something else I JUST thought of... Does it only happenafter a rain or after it's moist outside? There may be moisture seeping into the lights letting them short enough ot cause that to happen (My sentra does it cuz of an accident). Check your gaskets on the light sockets on the side that blinks fast.
Old Feb 19, 2006 | 02:55 PM
Sanguinius's Avatar
Hey Poot did you get it fixed or what man?? C'mon I'm dyin ta know what the problem was...
Old Feb 19, 2006 | 10:52 PM
hey man, i've been busy as fudge with school.
But I'll go check i out right after I finish my dinner. cool beans?
haha, hold yer horses.
I'll report back to you asap.
