Interior What have you done to the inside of your ride? Customized it? Kept it super clean? Talk about it here.
Turn Signal Help Please
Old Feb 20, 2006 | 12:02 AM
PooT_Nation's Avatar
Default RE: Turn Signal Help Please
OK, i've figured it out mostly.
It isn't the bulb that's burnt out. It's the harness that holds the bulbs that's broke. atleast i think it's that. I'll swap bulbs and the same harness wont light up the bulb. What do you think i should do?
I can't see if any of the wire is broken or worn. ::shrugs::
Old Mar 15, 2006 | 01:21 AM
willdue's Avatar
My 96 GS does the same thing, replace the one harness, a wire is prolly loose in the harness, its alot cheaper and easier on the mind to just replace it.
Old Mar 15, 2006 | 11:35 PM
clipse_05's Avatar
I have the EXACT same problem!!!! It has been like that for me ever I installed my projector headlights, which doesnt make a damn bit of sense because you still use the same turn signal harnesses. I just put stock headlights back on, didn't go back to normal which I didn't think it would. To add to the frustration, on my gauge cluster whenver I have the parking lights on, the left green arrow for the blinker is CONSTANTLY lit. When i turn the left turn signal on when the parking lights are on, it blinks very fast but the light is very dim, when the parking lights are on and I turn the passenger side blinker on, it blinks very slow and doesnt even blink in the front. I have no clue what the problem is but I want it fixed!!! Does anyone know where you can buy new harnesses for the front turn signals?
Old Mar 15, 2006 | 11:44 PM
glad i'm not the only one frustrated with this problem lol
Old Mar 16, 2006 | 12:08 AM
ictponder's Avatar
I had the same problem with a dodge of mine, Turns out there was just a shorted wire in one of the harnesses.
capecodder
Aug 4, 2007 08:32 PM
dornstar
May 22, 2006 04:58 PM
tym1200
Sep 27, 2005 05:11 PM
eclipse27
Jul 5, 2005 09:16 PM
eclipse27
Jul 5, 2005 04:05 PM
