1.8 turbo?
Old Sep 4, 2007 | 05:10 PM
SILVER's Avatar
Default 1.8 turbo?
Seen a rust bucket Talon with a " 1.8t " badge on the rear. Looks just like the emblem on a Volkswaggon Jetta 1.8T. Did DSM ever build a 1.8 turbo motor? I would not think so since the 4G63T is so fast. This got me to tnking though, has anyone accually seen or have turbo'd a 1.8 motor? I have 3 turbo's sitting around here, and got on the sts turbo website and seen how they hooked up thers. ( ststurbo.com ) This is a whole lot like how I turbo'd an F-150, but that was long before STS was on the internet.1Thing I would need to know to make it work is:There is NO WAY the stock injectors are going to push enough fuel for the turbo set up. Will 4G63T injectors work in a 1.8 motor? Other than the injectors, I can have the computer re-programed to compensate for the rest. Now keep in mind here, I am talking 4-6 psi boost and maybe 150 hp. Still enough that a stock FordASSPHFIRE will quit out-running me!!!!!! ( or escourt's, or geo's, or yugos. ) I swear, this HAS to be the SLOWEST dang car I have EVER owned!!!!
Old Sep 4, 2007 | 09:30 PM
nick_200321's Avatar
Default RE: 1.8 turbo?
no DSM didnt make a 1.8 turbo, not for the eclipse anyways. This person you saw might have just swapped a jetta 1.8t in and got the emblem made at a design shop
Old Sep 5, 2007 | 02:43 AM
silvercoupe97's Avatar
...or just added the turbo and the "T" letter.
Old Sep 7, 2007 | 02:06 AM
racerx55's Avatar
i HAD a 1.8L turbo in my 93 talon, but it was a DOHC non turbo 4g67 out of a hyundai elantra or somethin. same as any other 6 bolt just a smaller bore.
Old Sep 7, 2007 | 07:14 AM
sure people have done it, but from factory there is no such thing
Old May 27, 2012 | 08:33 AM
mxmikie's Avatar
cordia and tredia both came with a 1.8 turbo 1987/88
Old Aug 19, 2013 | 10:17 AM
carnuck's Avatar
My neighbor had a '90 5 speed Spyder with the Turbo. I think someone stuck the motor in there with a shoehorn. The timing belt went and I fixed it, but I had to use the number off the belt to get the correct one. NOTHING stock would work and the turbo was in the way of the casting numbers. It was originally a Mexico car that her Ex brought when he moved here.
After spending almost $500 fixing the drivetrain (replaced all 4 axles) and getting it past emissions, it failed safety inspection and she got mad and scrapped it (junk driver ripped her off. Said he'd give her $500 on the phone then screwed her down to $100 because "the exhaust wasn't OEM" #^@%$#* !)
Old Aug 19, 2013 | 01:29 PM
Spyder?
Old Aug 23, 2013 | 10:37 AM
carnuck's Avatar
well, it said Spyder on the back. I know the motor was shoehorned in. There were hammer marks on the firewall to clear space for the turbo. It had 2 timing belts
Old Aug 23, 2013 | 08:43 PM
No such vehicle, and these cars have one timing belt.
Both of your posts are confusing.
The neighbor is retarded by the sounds of things.
aznspyder
25
Nov 28, 2007 04:57 PM
turbotalon95
Jun 29, 2004 02:38 PM
scrappy24
Apr 7, 2004 11:04 PM
GSkiDD
Jan 29, 2004 08:04 AM
Eclipse_GSX
Jul 10, 2003 02:34 PM
