1g turbo kit, school me
Old Oct 20, 2006 | 02:16 AM
keithscianna's Avatar
Default 1g turbo kit, school me
Where can i find a turbo kit for a 93 eclipse, I belive its a 4g63. CAn i bolt on the stock turbo system? i have searched but i can only find info in the 420a.
thanks
Old Oct 20, 2006 | 02:21 AM
Default RE: 1g turbo kit, school me
You want to go an engine swap. You want to swap in a 4G63 turbo motor from ebay they are like $1000.
Alternatively if you dont want to do that you can just get the parts from a turbo 1g and change them over. They are the same and they will bolt right up.
Old Oct 20, 2006 | 02:25 AM
Ok,
so all i need is all the stock parts and it will bolt right up? what abot oil lines,injectors? wiring?, So basicly if i find a turbo at a junk yard i should just start pulling parts?.
does it ahve the same head, will i have limits on psi?
Old Oct 20, 2006 | 02:34 AM
You will ahve limits on the PSI because its is the non turbo motor (8psi)
You will need like the exhaust system, ECU, Injectors (i think) turbo, manifold, oil lines, Intake, MAF,
Personally i say your better off just getting the 4G63 turbo motor from ebay and bolting that up. It will save you a lot of hassle.
Old Oct 20, 2006 | 06:14 PM
93eclipsegsx's Avatar
yes injectors b/c the turbo injectors are bigger and i have stock turbo cams ill sell you.
skellagher
1st Generation
Jul 11, 2008 07:01 AM
victim619
Oct 3, 2007 02:09 AM
BLAZE GS
1st Generation
Sep 13, 2007 06:11 PM
green_eclipse94
1st Generation
Nov 18, 2005 10:31 PM
baker_sk8er37
Nov 5, 2004 11:49 AM
