clutch question
Old Nov 5, 2006 | 11:20 PM
wickedeclipse's Avatar
Default clutch question
whats going to be the best place to get a new clutch and whats going to be the best kind to get? i am looking at the centerforce. my car is a 94 eclipse, dd and ocasional street racer. thanks for any help
Old Nov 5, 2006 | 11:43 PM
Default RE: clutch question
ACT is the most trusted brands among DSMers. You can find them at www.expremepsi.com www.slowboyracing.com www.buschorracing.com www.amsperformance.com or any others you know. Also if you are replacing the clutch you might as well replace the flywheel. For that i recomend Fidanza.
If you are going to run under 300hp then i say th ACT2100 is for you. If you plan on running over that then the ACT 2600 is for you.
Rememebr to take it easy on the clutch for 350 miles. That means no aggressive shifting, no downshifting, no harsh launches. In other words no street racing for about 350 miles.
Old Nov 6, 2006 | 12:01 AM
thanks very much, ill look into them! and once again, thanks!
Old Nov 6, 2006 | 09:37 AM
Clutch Masters and Exedy also make some good clutches.
Old Nov 6, 2006 | 09:50 AM
For a 4G63T eclipse ACT is the best.
Old Nov 6, 2006 | 10:14 AM
I will say they are good clutches but they arnt the only company that makes a good clutch. Actualy with the ACT you could have a problem with the pressure plate because of how stiff they make it and they could break. Not saying they always do but it has happened.
Old Nov 6, 2006 | 11:15 AM
one quick stupid question, what is DSM?
Old Nov 6, 2006 | 11:31 AM
Diamond Star Motors. Basically it was a colaboration of Mitsubishi and Crysler until 1993. So they called all the eclipses and talons that they made DSM's. The 2gs technically arnt DSM's but every still refers to them as that.
97spydergs
Oct 29, 2007 02:14 PM
95EclipseGS95
Aug 20, 2007 01:03 PM
bud660r
Dec 23, 2006 07:30 PM
wicked2407
Oct 25, 2006 06:07 PM
gsx man
Mar 22, 2005 03:07 AM
