4g63 question..
Old May 21, 2010 | 08:26 PM
DragonRacerX666's Avatar
Default 4g63 question..
im looking for a 4g63 engine for my 93 eclipse which had/has the 4g63 engine but is blown i found a motor but this guy claims it wont work in my 93 cause the car it came out of is a 91/92 talon anyhow... this is what he said.
The Talon I have is a 92. The way I understand things, if it was built after April of 92, it would work in your 93 Eclipse. Unfortunately, the production date on this car was Aug 91. I serious doubt the engine would work for you.
then
It is a 4g63, but made before April of 92. Some changed after April. They "Might" not work. You can come see it and decide for yourself.
I just want a more experienced answer.
Old May 22, 2010 | 12:23 AM
dsm1990gsx's Avatar
It'll work 1g 6 and 7 bolt engines are pertty much the same.
Old May 22, 2010 | 05:52 AM
Default ..
well the motor that was in mine was once replaced before i bought it and it had labeled on the top TALON on the valve cover.
one more thing will my tranny for sure bolt to the 6 or 7 bolt?
Old May 22, 2010 | 12:46 PM
dsm1990gsx's Avatar
The trans will bolt up fine.
Old May 22, 2010 | 08:15 PM
you will just need a new flywheel see the FAQ section for the 6 bolt swap details. Definetly worth it to go with the 91 motor if you can
Old May 23, 2010 | 01:16 AM
Alright guys ty i appreciate it!!
Scubba.steve
Oct 3, 2008 03:15 AM
93Talon
Sep 3, 2007 07:22 PM
RCJr9186
Dec 8, 2006 06:21 PM
n2daizo123
May 17, 2006 12:51 AM
Jcontreras2001
Dec 1, 2003 08:45 PM
