92 1g eclipse clutch
Old Sep 19, 2005 | 04:37 PM
jmaahs07's Avatar
Default 92 1g eclipse clutch
i bought a 92 eclipse gs about a month ago and for a week or 2 the clucth has been grindin a lil bit. when i put i into first gear i grinds a lil unless i align it with second gear and move it up to first and sometimes when i shift up from second to first i will make a small grind. i am curious, i have a hydraulic clutch, does it need to be adjusted or maybe does it need to be bled. would these be reasons for it doing that?
jay
Old Sep 19, 2005 | 04:41 PM
get435's Avatar
Default RE: 92 1g eclipse clutch
id say bleed the clutch if that dont work sounds like the syncros in the tranny are going bad.
Old Sep 19, 2005 | 05:21 PM
jmaahs07's Avatar
how much would sumtin like replacin my syncros cost
Old Sep 19, 2005 | 06:41 PM
slow420a's Avatar
deff not the cluch its the syncros.
Old Sep 20, 2005 | 09:54 AM
get435's Avatar
go to a few tranny shops and have them bid it.
Old Sep 20, 2005 | 02:31 PM
Sanguinius's Avatar
Yeah definately not the clutch. If the clutch were the problem then the gears likely just wouldn't catch at all. Definately the synchros.
Old Sep 20, 2005 | 03:09 PM
get435's Avatar
The only reason i suggest just try and bleeding the clutch is becaus i have seen a few cars that have an air pocket in them that will grind while going in because the clutch is only for ex. 3/4 of the way disengaged. It most likely is syncros but you dont want to have them put in and have the problem come out as you just needed to bleed the clutch.
97spydergs
Oct 29, 2007 02:14 PM
95EclipseGS95
Aug 20, 2007 01:03 PM
bud660r
Dec 23, 2006 07:30 PM
wicked2407
Oct 25, 2006 06:07 PM
gsx man
Mar 22, 2005 03:07 AM
