92' Eclipse Overdrive
Old Apr 1, 2007 | 10:40 AM
123euroowner's Avatar
Default 92' Eclipse Overdrive
Hello everyone-
I have a 1992 Eclipse I just baught...its pretty good with 78k miles...The only problem is the overdrive in the automatic gear box..When I try to get 4th gear its equivalent to putting it in neutral(engine revs free). Yesterday I put some lucas anti-slip in the tranny...Helped the shifts, but not the over drive.
I hear this is a common problem......Is there any way a do-it yourself-er can correct this..
Old Apr 1, 2007 | 11:07 AM
Default RE: 92' Eclipse Overdrive
usually if your overdrive is gone, that means that you need a neww end clutch. This is something you could attempt yourself because you dont need to drop the tranny to do it
Old Apr 1, 2007 | 11:12 AM
how much would this new clutch cost? I will do it myself if I can...
Old Apr 1, 2007 | 11:13 AM
im not sure on the part. i know shops usually charge about $500 with labor so i cant really see it costing more than $200
eclipish
Jul 19, 2009 12:56 PM
eclipish
Jul 18, 2009 12:42 PM
blt2rck
Jun 12, 2004 11:41 AM
scitron
May 27, 2004 03:39 PM
glenn
May 13, 2004 04:46 PM
