94 eclipse blower switch wire
I'm missing the blower motor fan speed switch on the dash I just need to know what wire is the ignition power to the switch and what wire is the high speed signal to the blower so I can use a jumper wire to make blower work till I buy
A new switch
A new switch
Well, I don't have a wiring diagram but if you can find the blower (it's probably behind the dash or sticking in the firewall you should be able to hot wire it to a wire that has 12V when the car is running or wire it through a switch to +12v.
Dumbo45
Jan 23, 2009 09:29 AM
