another problem, im sorry.
Old May 8, 2006 | 02:50 PM
n2daizo123's Avatar
Default RE: another problem, im sorry.
your car can still run without the mass air hooked up. is the check engine light coming on? yes it did it constantly before the spark plug change.
Old May 8, 2006 | 05:16 PM
BrunoBoy650's Avatar
Yha well the check engine light is NOT on, so I'm thinking I'm going to re-time it, change the plugs, and fix the leak that I think I have
Old May 8, 2006 | 06:07 PM
5Tizzle's Avatar
If I were you, i would do a compression test first before buying anything.
Old May 8, 2006 | 10:50 PM
ORIGINAL: Jeffisdecentttttt
thats easy right?
Old May 9, 2006 | 12:42 AM
93eclipsegsx's Avatar
yes, its pretty much a spark plug with a gauge on the end of it and it reads how much compression is in your cylinders
Old May 9, 2006 | 01:44 AM
ORIGINAL: 93eclipsegsx
ok thanks
Old May 9, 2006 | 02:13 AM
5Tizzle's Avatar
ORIGINAL: BrunoBoy650
thats easy right?
Yes, very very easy.
Its a pressure gauge connected to a kind of long tube, that just screws into where your spark plug would normally go. You just test every cylinder. I cant remember exactly what your pressure should read. Someone on here like slow420 or emonz will know.
And youll need a friend to turn over your engine for you while you do it.
Just let it crank over 3 or 4 or 5 times, and that should be your reading.
Old May 9, 2006 | 02:14 AM
talon4show's Avatar
Yep compression test first...that could save you a bit of money. If that reads well (forgot the exact numbers you should have) than I would tackle the timing and all spark related issues.
5Tizzle's Avatar
its also a very inexpensive tool, if you dont already have one
Old May 9, 2006 | 05:34 AM
ok
ruski
May 8, 2010 12:44 PM
bestwiseguy
Apr 2, 2007 12:50 PM
seco007
Feb 16, 2006 01:16 PM
baker_sk8er37
Apr 19, 2005 12:32 PM
SpyderGS
May 11, 2004 06:01 PM
