Automatic seatbelts in 1991 eclipse
Old Jun 2, 2005 | 05:47 PM
HARMINATOR's Avatar
Default Automatic seatbelts in 1991 eclipse
I have a 91 eclipse with automatic shoulder seatbelts. The drivers side has recently stopped moving. It has done this before, but would jerk & shutter a couple times - then start working again. Its been 3 days now with no movement. I don't know if it is a motor or what...
Any Ideas?
Thanks.
Old Jun 2, 2005 | 09:30 PM
Sanguinius's Avatar
Default RE: Automatic seatbelts in 1991 eclipse
I'd say definately a motor problem if it jerked before and has stopped previously.
Old Jun 3, 2005 | 01:30 PM
patsevo8's Avatar
You've check the fuse?
The seatbelt motor is behind the panel that sits behind the driver seat. Remove it and you'll be able to see it.
Old Jun 6, 2005 | 07:40 PM
HARMINATOR's Avatar
I have checked the fuses & all are good.
Found the motor in the rear side panel. Noticed a ticking noise coming from it. Going to try a take it off after work. Can you get into these things or should I just start calling junk yards to get a replacement?
Thanks.
Old Jun 6, 2005 | 11:26 PM
Sanguinius's Avatar
If it's making a ticking then something is broke in there. You should go to a U-Wrench-It type plce and see if you can find one. It'll probably be easier than trying to get into the unit and then find teh smaller parts inside at a shop or whatnot.
OutDave07
Sep 7, 2009 08:43 AM
*~Daaaamn~*
Super Secret Mod Room
66
Jun 9, 2006 12:39 AM
Ooopsy67
Jun 30, 2004 10:16 AM
reallyaLS1chick
Jun 22, 2004 03:46 PM
reallyaLS1chick
Jun 22, 2004 03:40 PM
