A/c dosent work??
Old Aug 15, 2006 | 01:46 PM
yamahablaster8230's Avatar
Default A/c dosent work??
i cant get my compressor to engage. there are 3 wires on the a/c clutch does any one know which wire is the hot wire and the voltage that i should be looking for? when i turn the a/c the coolant fans engage and blower fan comes on but no compressor engages the system is full of freon and checked the low pressure switch.. does any one have any ideas?
Old Aug 16, 2006 | 01:08 AM
Default RE: A/c dosent work??
bump... no one knows any thing about the a/c system?
Old Aug 16, 2006 | 01:47 AM
2nd g eclipse gst's Avatar
have you checked the fuse
Old Aug 16, 2006 | 08:12 PM
slvr_eclipse's Avatar
It almost has to be somehting with the wiring. Refrigerant level would have nothing to do with it. Could be the clutch is shot and wont engage. Did you have it serviced not to long ago??? it is possible they removed the oil and never put it back in causing your compressor to go to hell. That pretty much is all the possibilities.
Old Aug 17, 2006 | 12:09 PM
yeah i checked the fuse it was fine i think it must be the wiring does any one know the wiring diagram?
Old Aug 20, 2006 | 12:02 PM
so no one has any ideas???
ground_control
Apr 13, 2010 01:23 AM
capital 97 tsi
Mar 23, 2009 09:55 PM
FastFreddieLTD
Sep 7, 2007 09:43 PM
GregK
Jul 15, 2004 09:35 PM
habeeb341
Jun 4, 2004 10:47 AM
