97 RS Dosent get any spark please help
Old Apr 7, 2010 | 11:50 PM
ground_control's Avatar
Default 97 RS Dosent get any spark please help
I have a 97 ecplipse RS 2.0 auto. The ignition coil has been change and i am not getting any power to it.The Cel light dosent light up either when i turn the key on acc so i changed the ECU from a 98 ecplipse rs.Same issue no cel light lights up on acc and no spark to the ignition coil anyone have this issue before? TIA
Old Apr 8, 2010 | 03:43 PM
check the distributor
Old Apr 9, 2010 | 05:12 PM
the rs models dont have a distributor they run off a coil pack.I checked the crank angle sensor cam sensor and all are not getting power.All the relays checked out also
Old Apr 10, 2010 | 06:50 PM
oh yea your right....well if the sensors arnt getting power then something must not be plugged in or a fuse
Old Apr 13, 2010 | 12:49 AM
3000gt16's Avatar
I know its gonna sound retarded, but maybe the battery? When I recieved my 10mm spark plug wires, I did a plug and wire change, and when I turned it over the day before it was fine, and after doin the plugs and wires, it wouldnt turn. I thought the plugs were bad, but it was just the battery. Longshot, but itd be nice if it was an easy fix like that.
Old Apr 13, 2010 | 01:23 AM
It's the CAS, by the way.
LeoGS
Nov 6, 2020 06:12 AM
fungusboy
Dec 15, 2012 03:33 AM
yamahablaster8230
1st Generation
Aug 20, 2006 12:02 PM
SkiLLz91GS
Aug 7, 2004 10:33 PM
SkiLLz91GS
Aug 7, 2004 10:32 PM
