a/c going in and out
Old Aug 6, 2008 | 08:36 AM
dvp13's Avatar
Default a/c going in and out
Does anybody know what could be causing the A/C in my '94 Eclipse to go in and out between cold and warm? It happens very randomly; some days it doesn't happen at all; some times it's cold for a half hour then cuts in and out; some times it's just back and forth every five or ten minutes; some days it doesn't even come out cold at all.
I had the condenser replaced and the system charged about two months ago and when it blows cold, it blows ICE COLD, so it does work.
Could it be a relay? If so, which one?
Any suggestions would be appreciated!!
Old Aug 6, 2008 | 12:03 PM
dsm1990gsx's Avatar
Default RE: a/c going in and out
Your probably low on charge. When it does it is the ac clutch cycle fast?
Another thing does the ac fan come on?
Old Aug 6, 2008 | 01:28 PM
dvp13's Avatar
What do you mean by the AC clutch "cycling fast"? If you mean that it makes the engine rev high, then the answer is "yes". And the AC fan does come on.
Would a low charge make it go suddenly warm and then suddenly cold again?
Thanks for your help
Old Aug 6, 2008 | 08:31 PM
dsm1990gsx's Avatar
Take a look at the ac compressor, the clutch is what will cycle on and off. W/ the ac on its should stay on for the most part and when its low it will cycle fast l ike every 15-20 seconds.
Old Aug 8, 2008 | 08:06 PM
dvp13's Avatar
Thanks for the help dsm1990gsx!! What it turned out to be was that the wiring harness had a frayed wire so that the clutch wasn't cycling and the compressor was only going on sporatically, I guess when the wire was positioned in such a way that it made a connection. Anyway, the wire was spliced, reconnected, and the AC now works fine. Thanks again for your help!
Old Aug 8, 2008 | 08:57 PM
dsm1990gsx's Avatar
Nice job and thanks for posting the fix.
Skiddy
Aug 24, 2009 08:18 PM
Boise
Jul 20, 2009 05:43 PM
EMonz57
Sep 12, 2008 03:45 AM
eclipseGS98
Oct 19, 2007 09:28 PM
