RE: damn i think its broken again....Ticking?
ALWAYS replace the tensioner when you replace the timing belt. The what $30 it costs for the tensioner is WORTH NOT spending the $300-$400 on a head job
they suck,
it bent two valves because of it and what not. yha so i watched them replace the tensioner and the belt and the valves. they said the tensioner was "good" when they put it together the first time, and then it went bad
ORIGINAL: BrunoBoy650 it bent two valves because of it and what not. yha so i watched them replace the tensioner and the belt and the valves. they said the tensioner was "good" when they put it together the first time, and then it went bad |
ORIGINAL: TheEngineer ORIGINAL: BrunoBoy650 it bent two valves because of it and what not. yha so i watched them replace the tensioner and the belt and the valves. they said the tensioner was "good" when they put it together the first time, and then it went bad |
Yeah you better not be payin for that shyt it's BS they did that and didn't bother to replace the tensioner... See what tryin to be cheap gets ya?
