desperatly need help asap please
Old Feb 28, 2007 | 10:46 PM
nick_200321's Avatar
Default RE: desperatly need help asap please
i am actually begining to belive i have a bad o-ring...i do have gas on the fuel rail right by the injector
Old Mar 1, 2007 | 12:09 AM
TheAdvocate's Avatar
very well could be.. I would replace them all while you have it off..
Old Mar 1, 2007 | 12:29 AM
but would that ring stop me from running?? its not a real bad leak just very slow..not much at all im just trying all i can to get it to run and it wont work. [sm=icon_flaming.gif]just getting a bit frustrated with it
Old Mar 1, 2007 | 01:49 AM
Do a compresion test on the cylinders. Thats will tell you
Old Mar 1, 2007 | 09:26 AM
soundcolor's Avatar
one bad o-ring shouldn't stop your car from running, it would make it run very poorly, like on three cylinders, but it shouldnt stop it from running.
Old Mar 1, 2007 | 08:50 PM
ok welli have yet another question. is the dowel pin on the crankshaft the timing mark?? im trying to see if i have it in time correctly...i know it started but im thinking it may have jumped a tooth or so.
Old Mar 2, 2007 | 10:30 AM
RCJr9186's Avatar
if it's only 1 tooth off, it will still run. The timing mark is an actual mark on the crank pulley with another small mark on the actual block to line them up at. You say you fournd a small leak on one of the O'Rings... did you check the others? they are only about 10 for a dollar so you might as well replace them all....
Old Mar 2, 2007 | 09:01 PM
soundcolor's Avatar
That is highly possible, however, if it didnt start before you un-hooked everything, and then started when you did, only to not work again once you re-connected everything, the chances that it just jumped a tooth are slim. I would deffinataly check your timing. But dont rule out any electrical gremlins.
Also, Im not sure about the clipse, but alot of motors wont run with the periphrials connected if the grounds are connected im-properly. Check all those too.
Old Mar 2, 2007 | 09:36 PM
well, soundcolor, it did start before i initally took everything apart but i just didnt run it because it needed a new headgasket. what are the periphrials...sounds familiar
Old Mar 3, 2007 | 09:25 AM
soundcolor's Avatar
periphreals, alternator, a/c compressor, powersteering pump.
So, your saying that it ran before you ever diss-assembled everything, but never again?
