finally done new problem
Old Apr 17, 2007 | 09:26 PM
natewesselink's Avatar
Default finally done new problem
my cars finally done the engines runnin great but i got it back and my first gear is grinding what could be the cause and is there a way to ajust a hydraulic clutch because the shop said there is no way to and i want to find out if there tellin the truth or not any info would be great
ps none of the other gears are grinding first is the only one i hgave a problem with
Old Apr 17, 2007 | 09:27 PM
Default RE: finally done new problem
is it only first gear, and does it feel like the clutch is not engaging properly. Cuz you may just need to adjust the clutch pedal
Old Apr 19, 2007 | 07:00 AM
ya first is the only one when i put it into first it grinds but i can put it into 2nd and come back and it wont grind untill i move past 2nd and then it does it all over again. they didnt do anything inside the car is there any adjustment on the transmition itself or would i just have to adjust the pedal
and heres another question my check engine lights been on since i got it back and ive had it for a week now and it isnt gone
what could cause this after a engine rebuild
Old Apr 19, 2007 | 08:16 AM
racerx55's Avatar
if you had it dont at a shop or somethin i would be takin it back.
you might want to make sure the transmission is full of the right kind of oil, sometimes they put the wrong stuff back in after osing half of it when you pull the axles out to move the trans to pull the engine. i know if you use 80w90 on my cars old transmission it wants to shift hard and grind untill it warms up after driving for 20 minutes.
Old Apr 20, 2007 | 02:18 AM
thanks for the info what is the right fluid to put into a trannie so itll stop grinding
Old Apr 20, 2007 | 03:28 AM
racerx55's Avatar
ive been using penzoil synchromesh and it works the best for me so far.
evryone else on here probly swears by it too.
Gstfat
Feb 13, 2008 10:02 PM
kaiba408
Mar 20, 2007 02:42 AM
MrJayDeeOne
Jan 30, 2007 12:08 AM
Camel3g GT
Nov 10, 2006 02:19 PM
MrJayDeeOne
May 23, 2006 12:55 AM
