fuel pump
Yeah an FPR will be about all you'll need for that. And after those 2 items you're 2/3 of the way there fuelwise for a bigger turbo
. The only other thing you'll need are bigger injectors and you're good to go. Also remember to change your fuel filter when you change the pump. I'm not refering to just the sock in the tank but the external one as well. It's likely pretty nasty.
get a fpr if you put on a 255 pump, but just to let you know a 190 pump will be plenty, ive already hit mid 11's with one and plenty of fuel left. also, fpr's complicate things when tuning and shouldnt really be used unless required
MNalfa
17
May 9, 2019 06:07 AM
agallardo
Feb 22, 2007 03:46 AM
