fuel pump
Old Mar 28, 2006 | 10:48 AM
paintballproam's Avatar
Default fuel pump
on a 1st gen eclipse/talon if i put in a 255lph do i need to change anything else? i know this sounds stupid. just i need a new fuel pump so i was just wondering
Old Mar 28, 2006 | 12:24 PM
slow420a's Avatar
Default RE: fuel pump
you would need a fpr
Old Mar 28, 2006 | 01:26 PM
Sanguinius's Avatar
Yeah an FPR will be about all you'll need for that. And after those 2 items you're 2/3 of the way there fuelwise for a bigger turbo . The only other thing you'll need are bigger injectors and you're good to go. Also remember to change your fuel filter when you change the pump. I'm not refering to just the sock in the tank but the external one as well. It's likely pretty nasty.
Old Mar 28, 2006 | 02:57 PM
slow420a's Avatar
injectors wouldnt be needed, the fpr will keep the fuel pressure low enough not to over run the rail, also if he were to get bigger injectors he would need to get a piggy back to control them.
Old Mar 28, 2006 | 11:54 PM
DSMTalonAWD51's Avatar
get a fpr if you put on a 255 pump, but just to let you know a 190 pump will be plenty, ive already hit mid 11's with one and plenty of fuel left. also, fpr's complicate things when tuning and shouldnt really be used unless required
MNalfa
17
May 9, 2019 06:07 AM
Germankat
Mar 19, 2008 05:28 PM
Germankat
Mar 19, 2008 06:43 AM
agallardo
Feb 22, 2007 03:46 AM
audionxs
Sep 19, 2003 11:56 PM
