Houston i have a problem
Old Mar 7, 2007 | 04:29 PM
pearlywhite93's Avatar
Default Houston i have a problem
Hello fellow dsm lovers, i was wondering if one of you with your infinite wisdom could help me. i just bought a 93 eclipse with a swaped in 2.0 turbo. $1000 killer deal, however the tranny was no good so i got a 5f33 and when i took the old tranny off it was a 5f22 which uses a smaller fly wheel. so now my starter is not engaging the flywheel. i tried to order a flywheel for a 93 turbo but when it came in it had 7 holes for the crank and mine only had 6. so i am lost , i though maybe the engine is from a later year but i dont know where to go to run the number. so any advise would be great. i was thinking i might have to go with a new 5f22 but i would rather have the heavier tranny, these turbos are crazy powerful
Old Mar 7, 2007 | 05:02 PM
RCJr9186's Avatar
Default RE: Houston i have a problem
what happend is you got a 6 bolt block and ordered a 7 bolt flywheel. i'm no expert when it comes to 1st gens but i think if you order a 6 bolt flywheel you should be just fine. (6 bolt is >93 and 7 bolts came in everything past that year. 7 bolts, especially in 2nd gens, were notorious for cranwalking)
Old Mar 7, 2007 | 08:22 PM
exactly, you dont have an engine from a 93. the engine is from a 90-92.5. so your looking for a flywheel from those years
Old Mar 8, 2007 | 12:07 PM
RCJr9186's Avatar
good news is though that you do have the best DSM engine there is... the 6 bolt is a better built engine b/c you don't have to worry about crankwalk.
Old Mar 8, 2007 | 03:36 PM
wow you guys rock, one more question where is a good place to get a flywheel, and should i consider a lightened one. what will it do for me.
Old Mar 8, 2007 | 03:42 PM
RCJr9186's Avatar
what a lightweight flywheel does is cut down on Rotational mass... basically lighter is faster... ie the flywheel/clutch/crank will spin freer/faster than a heavier one would. so yes, it's a good investment. Fidanza makes a gread one along with Exedy and a few others you can check out Slowboyracing.com, CIMotorsports.net, horsepowerfreaks.com, stillen.com. ebay motors... tons of places.
Old Mar 8, 2007 | 08:08 PM
93eclipsegsx's Avatar
also if you go to light, it can be bad. causing the car to stall at idle. get an act street lite flywheel, thats what i, and a couple others i know and they love em.
Old Mar 9, 2007 | 10:24 AM
RCJr9186's Avatar
^ i've never heard of that happening. . . hmm any explination why?
Old Apr 22, 2007 | 02:33 AM
DonaldRW's Avatar
get a 6 bolt flywheel and you'll be fine.. Make sure though you have the fight bell housing plate when you bolt the tranny back up, because i had that problem and had to change out the plate.
Old Apr 22, 2007 | 03:57 PM
well if you have a good runnnig car it wont affect it, but say you have a too light of one, and your car is running like *** and missfiringalot, then you dont have that rotational mass helping out so it will stall when the car is missing. but i would suggest the act streetlite flywheel FTW!!!
anko_kun
Apr 24, 2008 06:49 PM
redline3kgt
Jan 9, 2008 12:10 PM
rpauly
Dec 21, 2004 10:17 PM
GT N1nj4
Aug 29, 2004 07:02 AM
davids2004
Jun 15, 2004 06:54 AM
