how to find a vacuum leak?
Old May 1, 2006 | 10:05 PM
BrunoBoy650's Avatar
Default how to find a vacuum leak?
i know for sure i have a vacuum leak, but how do i find it?
Old May 2, 2006 | 12:11 AM
DSMTalonAWD51's Avatar
Default RE: how to find a vacuum leak?
how do you know
Old May 2, 2006 | 02:36 AM
ORIGINAL: DSMTalonAWD51
how do you know
well i heard a BIG Hissing noise, coming off my BOV so i changed the hose and its fixed. but then at high rpms. it still doesnt let me go past a certain rpm, even though im not running high psi,(so it isn the fuel pump) and im running a stock turbo. well at high rpms, it stutters or fluctuates and i asked my dads friend whose a mechanic, and he said it sounds like another leak somewhere.
Old May 2, 2006 | 02:40 AM
vacuum doesnt affect anything when you are on the throttle, if it was a vacuum leak it could affect your idle. i would say its a intake leak somewhere. what boost are you running exactly and what do you mean it wont let you run rpms. are you hitting fuel cut?
Old May 2, 2006 | 02:57 AM
its like the other guys problem, only happens when i slam the throttle. its not fuel cut because when i ease into the gas it works. im running 7 psi.
Old May 2, 2006 | 03:34 PM
[:@]just becuase it works when you ease into the gas doesnt mean its not fuel cut, fuel cut is only going to happen when you floor it. (ie 100% throttle). So it still could have been that.
Old May 2, 2006 | 08:44 PM
ORIGINAL: TheEngineer
ok,
Old May 2, 2006 | 08:46 PM
i think both of you have a boost leak. boost leak would cause a studder/quiet popping sound, fuel cut would be a hard slam, and i dont think its possible at 7psi
Old May 2, 2006 | 09:26 PM
and i can check that by listening too? or do i just check all the hoses
guangui
May 20, 2020 12:27 PM
TotalEclipse
Feb 21, 2012 06:53 AM
TheRock0720
Nov 12, 2010 12:30 PM
kodred
Dec 26, 2008 05:04 PM
freakosaurus
Jul 28, 2007 08:34 AM
