i got some questions about the 4g63
Old Oct 30, 2007 | 08:15 PM
1gawdtsi's Avatar
Default i got some questions about the 4g63
i was wondering if they were reliable engines and wat are some good mods to do to themi am swappin one into a 1991 talon tsi awd thanks for your help
Old Oct 30, 2007 | 08:23 PM
jpmontero98's Avatar
Default RE: i got some questions about the 4g63
they are more reliable than a 420...actualy they are pretty reliable....i got one runnin in a galant VR4 at my school for auto body and beat the hell out of it with no oil cap(meaning water prolly got into the engine) and it hasnt run for a while..AND IT RUNS WELL NOW..as for mods you can do what ever they sell......pistons, rods, cams,turbos,put an evo head on it etc....do u have a turbo 4g63 or N/A
Old Oct 30, 2007 | 08:28 PM
1gawdtsi's Avatar
yea i do what about exhaust, intake, headers, downpipe, boost controller(15 lbs),bov, and a front mount how much horse power will i be pushin and what do you think ill run at the 1/4
Old Oct 30, 2007 | 08:31 PM
About low 14s and high 13s if you are a really good driver.
Old Oct 30, 2007 | 08:34 PM
1gawdtsi's Avatar
i also herd there timingbelt breaks and ruins the motor
Old Oct 30, 2007 | 08:37 PM
thats if you dont do proper maintenince or do somthin to f*** it up or really bad luk...but in any car if a timing belt breaks...the engine is f***ed bent valves and damaged pistions are scratchin the surface of your problems if the belt breaks
Old Oct 30, 2007 | 08:43 PM
on 90% of motors if the timing belt breaks it ruins the motor. The only reason you hear about it so much on these cars is because the owners are cheap asses and dont keep up with the maintanance. Of course if you dont change the timing belt for 150k miles its going to snap
Old Oct 31, 2007 | 06:58 AM
it doesnt ruin the motorsebba, it just ruins the head. And most of the time its gonna cost about 1500 - 2000 to fix if it goes. But like they said, just keep up on the general maintenance
Old Oct 31, 2007 | 11:32 AM
It takes chunks out of the pistons... that to me is ruined
Old Oct 31, 2007 | 07:54 PM
dsm1990gsx's Avatar
The 4g63 engine is a reliable engine as long as you dont cut corners and half *** timing belt/head gasketjobs.
As for timing belts the only way ot would do serious damage to the pistons is if you cruising at like 60mph and the belt breaks. It usually cracks the piston. If your at idle or close to it you can get away w/ a new head and filing down the dings onthe pistons.
