idle problem
Old May 19, 2007 | 11:51 PM
skydive2144's Avatar
Default idle problem
well im new to this forum, and these cars, but i just got a 91 laser, 2.0 dohc, non turbo. when you first turn the car on, the idle is fine. after it warms up a little bit, the idle wil jump up and down bettween liek 400 and 800. when you tap the gas it goes way up stays there for a few seconds then drops and starts jumping again. if i drive it somewhere and the car heats up all the way, and turn it off, if i dont let it cool all the way down for like a half hour it is almost impossible to start, and i have to hit the gas a lot to start it. anyone have any clue?
Old May 21, 2007 | 01:20 AM
spinz4's Avatar
Default RE: idle problem
Most likely the ISC motor.
Old May 21, 2007 | 07:24 AM
iagree. Thats probably the issue. I would also clean out your throttle body as well.
Old May 26, 2007 | 06:37 PM
superhumankiddy's Avatar
I have a 92 Eagle Talon 2.0 DOHC Non-Turbo, and mine, when you first start it, it'll idle up to about 3200 RPM, then drop down to about 1200 and keep surging from 1200 to 1500 RPM when in idle. Is my problem the same as his do you think? and what does a ISC stand for? Thanks ahead of time for any help.
Old May 26, 2007 | 07:03 PM
spinz4's Avatar
Yup sounds like the same problem. The ISC is the idle control motor, bolted to the throttle body with 2 8mm bolts. Also has a electrical connection.
Old May 26, 2007 | 09:42 PM
Thanks, I'll be sure to have that checked.
Old May 26, 2007 | 09:44 PM
Oh, just outta curiousity, how would you go about cleaning out the throttle body?
Old May 27, 2007 | 04:30 AM
racerx55's Avatar
you should all check that the rubber boot between the turbo and airflow sensor is not cracked and leaking, my car surged like that when i had a leak.
Old May 27, 2007 | 12:18 PM
Our cars are non turbo, but thanks for the input.
Old May 27, 2007 | 06:19 PM
racerx55's Avatar
well then between the intake and airflow sensor., theyre still picky on either one.
i skimmed over it all quick so i missed the non turbo part
