Lower Front Ball Joint
RE: Lower Front Ball Joint
what i did was, i took the swaybay off the lower control arm. take the nut off the balljoing it self and give it a wack and the arm should drop down giving you the room you need to take the balljoint out, and then reverse process for the install.
jrmdir
08-26-2010 07:54 AM
Customshiftboot
07-29-2004 05:17 PM
01, 1st, 24, 93, ball, change, eclipse, gen, installation, installing, joint, joints, lower, mitsubishi, press
