Lower Front Ball Joint
Old Apr 1, 2008 | 12:24 PM
jwngr's Avatar
Default Lower Front Ball Joint
Anyone have any tricks for installing a ball joint on a 1993 Eclipse? It is the driver side front.
Thanks
Old Apr 1, 2008 | 06:33 PM
93eclipsegsx's Avatar
Default RE: Lower Front Ball Joint
theres no real trick to doing it, but i think you can borrow a ball joint press at auto zone i believe.
do you need instructions on doing one?
Old Apr 2, 2008 | 08:23 AM
jwngr's Avatar
Sure thats cool. Thanks
Old Apr 2, 2008 | 11:47 AM
dsm1990gsx's Avatar
Its pretty straight foreward, you beat the old one out and press the new one on. No special tricks.
Old Apr 2, 2008 | 09:26 PM
what i did was, i took the swaybay off the lower control arm. take the nut off the balljoing it self and give it a wack and the arm should drop down giving you the room you need to take the balljoint out, and then reverse process for the install.
jrmdir
Aug 26, 2010 07:54 AM
bori
Nov 27, 2009 11:03 AM
thorne1976
Dec 17, 2008 05:35 PM
johnthornhill
May 10, 2007 10:51 PM
Customshiftboot
Jul 29, 2004 05:17 PM
