Manual and Auto Trans ECU Compatibilty
You can but you have to also change over the injectors, injector resister box for it to run right. The m/t turbo ecu is set up for 450cc injectors while the auto turboecu is set up for 390cc injectors.
1990 stand alone year and 91-94 share the same ecu's.
ORIGINAL: dsm1990gsx
Yeah u need the m/t ecu to control the 450cc injectors. There is a hp gain b/c the autos have a smaller turbo 13b rather then the 14b.
So, what do you know about this injector resistor block? Will the auto resistor block work with the manual turbo and injectors?
I may have to put the 13b turbo back on for now, just see if the engine is good. It is sitting in the back of the car. Thanks for all the help!
