need some help!!!!!!!
Old Mar 14, 2006 | 06:39 PM
Cheech III's Avatar
Default need some help!!!!!!!
ok, i found a 1993 eagle talon. (cant find a forum) it has 90000 miles. it is 1000 dollers. they said it needs a timing belt and some tranny issues. should i buy it for 1000 dollers and fix it up or would the engine be toast from the timing belt?
Old Mar 14, 2006 | 07:04 PM
Sanguinius's Avatar
Default RE: need some help!!!!!!!
Depends. Did the timing belt BREAK or did it jump time or what? These engines if the timing jumps more than 1 tooth you could possibly bend the valves. Tranny issues.. What KIND of trans issues? Does it not go into gear? Is it not shifting up or down? Likely going to need a trans replacement but for 1000 it all depends on the shape of the body and the interior. At this point you're looking at a head rebuild and valve job and a trans replacement but if everything else is in good shape I'd say go for it.
Old Mar 14, 2006 | 07:31 PM
Cheech III's Avatar
the guy said the timing belt broke, i think, or myabe he just said it needs replacement. is it bad if it broke? the body and interior is in awsome shape and it has a cd player. i am going to test drive it tommorrow or the nest day so i can tell you about the tranny. how much would a new tranny be?
Old Mar 14, 2006 | 08:33 PM
Sanguinius's Avatar
I wouldn't test drive it if the timing belt hasn't been fixed... But for $1000... You could probably get close to that parting it out... If it's running though then I'd imagine they fixed the head already...
Arioch
Nov 1, 2006 06:29 PM
Richie03
Dec 12, 2005 11:14 PM
1998blackgst 240
Apr 12, 2005 12:56 PM
Buddababy
Apr 8, 2005 05:56 PM
petith05
Feb 23, 2005 01:41 PM
