now what!
Old Mar 21, 2006 | 03:39 AM
  #21
DesolationAngel's Avatar
Default RE: now what!
ORIGINAL: 93eclipsegsx
what will i have to have rebuilt so it will run?
Well your gonna want some help probably. Call me brotha im bored and have tuesday and wednesday off!!
Old Mar 21, 2006 | 09:36 AM
  #22
Sanguinius's Avatar
LOL See there ya go someone even willin to help you do the block swap.
Old Mar 21, 2006 | 09:40 AM
  #23
no matter what block you buy you would want to have it rebuilt. i also might have to figure out shipping too.
Old Mar 21, 2006 | 10:02 AM
  #24
Sanguinius's Avatar
Unless he buys a crate engine then I doubt he'd need a rebuild LOL...
Old Mar 21, 2006 | 10:38 AM
  #25
93eclipsegsx's Avatar
now, the big question. how much will it cost because i dont that much in the bank.
Old Mar 21, 2006 | 10:58 AM
  #26
Sanguinius's Avatar
Well let's see... First off the rebuild is going to require head gasket as well as all other gaskets, timing belt and tensioner, Bah just get the book. And expect the car to be OOC for quite a bit unless you have the tools and alot of spare time...
Old Mar 21, 2006 | 11:12 AM
  #27
can i reuse the tensioner b/c that has 1000 miles on it or buy everything new again?
Old Mar 21, 2006 | 11:16 AM
  #28
Sanguinius's Avatar
Ah O.K. didn't now your tensioner had so few miles... The gaskets you'll need new as they've been installed once which means they've already been crushed once. Better to be safe than sorry. Belts you MIGHT get away with depending on age and use again. Also you might want to change the thermostat as well. If you're doing a full rebuild you'll need rings for the pistons as well as a cylinder hone. (I HATE bottle brushes but they tend to be cheaper...).
Old Mar 21, 2006 | 11:21 AM
  #29
yeah i put a new head on 1000 miles ago and i replaced everything. waterpump, tensioners, belts, and so on
Old Mar 21, 2006 | 11:26 AM
  #30
Sanguinius's Avatar
Well then be careful pulling the timing belt off and you'll have to find a new water pump gasket but otherwise you can reuse everything else you just replaced. Except the obvious head gasket and water pump gasket. You MAY even be able to reuse the valve cover gasket but with most of them running around $5-$10 I'd just be safe and replace it.
