ok now im pissed
RE: ok now im pissed
ok, go down to where you can adjust the clutch.. this fixed my problem.. get under the dash, look up, and you will see a rod going out to the master cylinder.. that rod goes through a bracket and has one small nut tightened on it..use1/2 inch wrench on it, thats what size it is. lossen that nut, and with plyers, grab where the rod IS NOT threaded and start to twist the rod so it is moving out (towards the master cylinder). move it out almost as far as it will go and try it.. this should fix your problem.. make sure to tighted that nut back down or else it will just back itself out again and you will have to start over..
hope this helps, let me know
send millions my way then lol, im glad i was able to help, play with it a little more and you will be suprised, you can adjust it to exactly your comfort.. i was told i needed a resurfaced flywheel, or slave cylinder, or master.. but i was told wrong lol... too bad i had already bought the slave cylinder LOL oh well, got a new part
gant
04-03-2007 11:29 PM
