Please Help me
Old Mar 15, 2008 | 02:45 PM
gamerdude's Avatar
Default Please Help me
I have a 93 gs and it has a real big problem. I bought the car after it had been sitting for about 5 years and it hardly ran. It would run for a few minutes and just die. I rebuilt the engine in the car shortly after I bought it thinking that it would fix the problem, but it didnt. It still ran rough even after i rebuilt the engine, replaced the MAF sensor, crank/cam sensor (I got it from the junk yard tho), coil pack, plug wires, and the plugs. The car ran for about 500 miles after the rebuild and I did not start the car for about 2 days and it would not start again. After this I replaced the ECM in it and the fuel pump relay and still nothing. So I just got tired of working on it after that and I quit working on it for about 5 months. I replaced the O2 sensor after those five months were over and it started. It sounded really, really bad tho. It would not rev but to like 2500 rpmand sounded like the engine was about to fly apart. All the sound was coming from the intake side of the engine. I let the car sit for just one whole day without starting it again and it would not start after that again. The car has been sitting once again for about 6 months and will not start. Could a bad camshaft be the cause of all this? Sorry about such a long message
Old Mar 15, 2008 | 03:24 PM
Default RE: Please Help me
Either the timing is out... or you have one hell of a bad vacume leak.
Old Mar 15, 2008 | 06:15 PM
gamerdude's Avatar
Thanks but I'm pretty sure that its not the timing because it was in time whenever it stopped running for the last time. Far as vacuum leaks go im not for sure. Any idea off the top of your head which one(s) it might be?
Old Mar 16, 2008 | 01:43 AM
Its impossible to say.
It really does sound like timing to me....
Old Mar 16, 2008 | 01:54 AM
Kaede.Noir's Avatar
go for a vacuum test just for curiosity sake, get a vacuum gague... im not talking bout the a-pilar one... real ones
Old Mar 16, 2008 | 02:37 AM
racerx55's Avatar
so it sat for 5 years...stale gas leads to trashed injectors, usually craps out the fuel pump, rots the diaphram in the regulatorand i hope to god you changed the fuel filter.
check in that area. its pretty much normal for noisy lifters, especially after sittingfor a whilemonths after a rebuild.
when you had it apart did you check the valves to make sure they weren't bent?
ive seen people overlook that before. umm have you drained the gas and put new in?
not trying to offend but alot of problems are simple things that were overlooked.
Old Mar 16, 2008 | 11:17 AM
I know a car that sat for 15 years.... with gas in the tank. Its running the injectors and fuel pump it came with.
Old Mar 17, 2008 | 10:42 PM
jgbrules's Avatar
hello!! sounds like to me you have several problems. but racerx has a very valid point. i would first start by putting in fresh gas and a new fuel filter. after sitting 5 years not only can the gas go bad, but condensation in the tank can lead to a bunch of water mixed with bad gas. not a good combo. also remove the fuel line going to the injector rail and let that drain too. when you do this get samples of the gas, the water will separate from the gas, and the gas will smell real bad, musky smell. cant miss it. you can look at the samples to know if your on the right track. also, secondly. recheck that timming. those DOHC motors can slip a tooth when putting the belt on VERY EAISILY. can cause every problem your having if its off just 2 teeth. another thing, is did you over tighten the intake bolts?? if you installed a paper type gasket it is very easy to over tighten and split that gasket. you also have a torque sequence. start in the middle and work your way out. meaning the middle, then bolt on left then bolt on the right, alternate between top and bottom. that intake gasket splitting can cause a HUGE vacume leak.one other thing that comes to mind that i have seen a couple of times is, the cam shafts get mixed up. most of the time the engine wont run, but i did see one time that it would crank up for just a minute then die. long shot but worth checking. the shafts have a letter stamping on them to indentify. some websites like alldata, or mitchell will give you that info. we have a factory manual for that somehwere in our shop, if i have a chance i will try to find it and post again with the info!! hope this helps!! good luck!!
Old Mar 18, 2008 | 06:50 AM
dsm1990gsx's Avatar
ORIGINAL: jgbrules
There is no possible way to mix up the cams, the intake cam has a slot on it atthe end for the camshaft position sensor.
LeoGS
Nov 6, 2020 06:12 AM
enzo_hashmat2006
Oct 10, 2017 05:46 PM
westentertainer
Nov 8, 2014 12:47 PM
lgibson
Mar 12, 2009 07:04 PM
96eclipsedohc
Feb 8, 2007 09:20 PM
