is it possable
#22
ORIGINAL: RCJr9186
go for it... do it yourself... drop the oil pan, pull the main clip off, get a crank pulley pull the harmonic balancer off, drop the crank, replace your bearings and put it back together. that's your step by step process. good luck. and i hope you get 2k miles out of it when you put it back together if you don't know what you are doing.if you dont take care of your car the way it should be done... it will treat you the same way. don't come on here asking advice for a hypothetical situation if you already know what you are going to be doing in the first place and don't plan on taking our advice. we have given it to you, we have told you the best thing to do and the smartest thing to do, take it or leave it.
