replace frt axles on 1993
Greetings
I need to replace the front axles on my 93 Eclipse, CV joints bad. Does anyone have a flow for doing this? Do I have to disconnect the lower A-frame and tie rod to get the axle out of the hub? Do I need to use the special tool that is shown in the manual to seperate the A-frame and tie rod or can I just use a tuning fork and a hammer? Any help greatly appreciated.
thanks
Gary
thanks
Gary
if i remember correctly, there is an acceptable range. 188 is probably the upper end of the range and i believe that 150 is minimum. if your manual is calling for 188 with no range, then i'd go with that. make sure that you put some red grease on the threads of the axle and use a new cotter pin after you get it torqued.
