TD05H
Old Oct 19, 2005 | 07:51 PM
1990GSX's Avatar
Default TD05H
is this a stock turbo for a 1990 GSX? Or is there another code on the turbo that says more abot what size it is?
Old Oct 19, 2005 | 11:33 PM
GANGSTAH33's Avatar
Default RE: TD05H
ITS A T-25 AND THE MAXIMUM HP YOU CAN GET FROM IT IS 250 AT 16PSI
Old Oct 20, 2005 | 12:03 AM
Default RE: TD05H
ORIGINAL: GANGSTAH33
ok this is wrong info. the T25 is in the 2Gs.
in a 1990 GSX if its a manual(5spd) then you have a 14B (it says TD05 inprited on the housing) if its an auto I beleive they use a 13G??, not sure if I got the correct letter at the end of that one.
Old Oct 20, 2005 | 04:11 AM
DSMTalonAWD51's Avatar
Default RE: TD05H
td05 is just the compressor housing used on many mitsu turbos from the 14b to the smaller 20g's. but since your car is a 90gsx 95% chance u have a stock 14b unless someone before you put in a 16g because without looking at the blades they are identical in outer appearance.
Old Oct 20, 2005 | 11:57 AM
Sanguinius's Avatar
Default RE: TD05H
I think I have a 16G. Unfortunately I'm having trouble getting the (well what remains of) studs used to bolt it to the manifold out of it. the last owner wasn't too bright and snapped 2 of them off in the housing. Any ideas on how to get them out?? I've soaked them in liquid wrench and been using gator grip pliers still no luck.
Old Oct 20, 2005 | 04:29 PM
Default RE: TD05H
those are the hottest bolts under the hood, I cracked a socket trying to get em out. I jus went to sears and bought a bigger wrench and it wasnt too bad.
Old Oct 20, 2005 | 04:30 PM
Default RE: TD05H
you can run the car for a while first. metal expands when hot and it will come off easier after you heat em up.
Old Oct 20, 2005 | 04:35 PM
Sanguinius's Avatar
Default RE: TD05H
Yeah except the turbo sits on my tool cart with those 2 bolts in it (Heads snapped off of course) and I'm STILL not able to get them... Perhaps a propane torch?
Old Oct 20, 2005 | 04:45 PM
get435's Avatar
Default RE: TD05H
tac weld a smaller bolt to the than just screw thwm out.
Old Oct 20, 2005 | 04:46 PM
get435's Avatar
Default RE: TD05H
tac weld a smaller bolt to the than just screw them out.
