TD05H
Old Oct 20, 2005 | 05:31 PM
slow420a's Avatar
Default RE: TD05H
ORIGINAL: get435
tac weld a smaller bolt to the than just screw them out.
x2 either that or get a titanium drill bit and drill the fu3kers out.
Old Oct 20, 2005 | 07:53 PM
Default RE: TD05H
Id drill them out.. I had to do that with my EVO VII 16G because the same thing happened
Old Oct 22, 2005 | 06:45 PM
1990GSX's Avatar
Default RE: TD05H
ok, so lets say it's a stocker. If I wanted to get over 300 hp, where do I start? I have 2 1/4" exhaust (no cat), 3A Racing muffler (Whatever that is), just ordered a Dejon Tool intake, K&N air filter. otherwise I think it's stock.I don't want to spend bunches of money all at once, and I can do most of the wrenching myself (maybe) Just remembered, I have a mbc also (how do you adjust those, and what is a "safe" level of boost to run?
Old Oct 22, 2005 | 06:55 PM
Lil red's Avatar
Default RE: TD05H
What about a reverse tap?
Old Oct 22, 2005 | 07:15 PM
Sanguinius's Avatar
Default RE: TD05H
Yeah I wanna get a reverse drill set and an easy out set.
Old Oct 22, 2005 | 09:42 PM
Default RE: TD05H
ORIGINAL: 1990GSX
On the 14B?? I have seen 18\19PSI but that is with at least a fuel pump dont run that much without fuel. on stock fuel I think 16 is still safe but id leave that one to the other DSM owners to answer
Old Oct 24, 2005 | 07:46 PM
1990GSX's Avatar
Default RE: TD05H
ok, so it's looking like I need exhaust (3"?, type?), down pipe (2.5"?, type?), whats next? I would like to be working my way to 350-400hp, or there abouts. Oh, I have a datalogger on the way also.
Old Oct 24, 2005 | 11:18 PM
DSMTalonAWD51's Avatar
Default RE: TD05H
ORIGINAL: 1990GSX
datalogger is a smart choice once you get something to tune your car with (safc, dsmlink) so you want 400hp? good luck. its not easy. eclipses dont need much power remember, thats enough for 10's. it will take a huge turbo and some bigge injectors/race gas. go 3" for the exhaust though. no point in 2.5" although even if u did get it it would be fine up to about 400hp.
aleksei
Jun 2, 2006 03:21 PM
Emartoo
May 10, 2005 06:12 AM
whitestallion10
Jan 9, 2005 03:36 AM
TD05h Mazda
Oct 25, 2004 01:16 PM
TD05h Mazda
Oct 25, 2004 04:55 AM
