troubleshooting help!!!!!
Old Mar 12, 2010 | 12:29 PM
rsanty2000's Avatar
Default troubleshooting help!!!!!
i have a 1990 gsx... ok i have rebuild the motor... when i first time is started it... i had to pump the gas peddel but it started... a big puff came from the back passenger side of the engine... i have replaced the ground cables thinkin thats what fried... well it still wont start!! i have replaced the sp wires, compression sits over 90psi, i have replaced the injector plugs!! Still nothing... tested the fuel pump (works)... new ngk's (checked gap too)... any ideas
Old Mar 12, 2010 | 10:13 PM
dsm1990gsx's Avatar
Compression should be in the 150psi range not 90 psi.
Old Mar 13, 2010 | 12:24 PM
rsanty2000's Avatar
ok i understand if the compression should be 150psi (when engine has ran) but the engine has never started... and always been taught that all you need i 90 psi (actually psi on car is 115 to 120 psi) until the rings get seated... then compression goes up correct?
Old Mar 13, 2010 | 03:02 PM
dsm1990gsx's Avatar
Are you getting spark and fuel?
Old Mar 13, 2010 | 04:48 PM
rsanty2000's Avatar
gettin fuel... yes
spark... yes
Old Mar 13, 2010 | 06:59 PM
dsm1990gsx's Avatar
Are all the timing marks lined up right?
Old Mar 13, 2010 | 07:37 PM
rsanty2000's Avatar
yes and 10 degrees
Old Mar 13, 2010 | 07:59 PM
dsm1990gsx's Avatar
Well if your doing everything correctly the car should be running. How did you check for fuel?
any upgrades. All i can think of is something either on the cold start or you have low fuel pressure. Something may not be plugged in. It could be a bunch of things though
Old Mar 14, 2010 | 01:57 AM
rsanty2000's Avatar
nope no mods... and ill try to replace the fuel filters tomorrow
