turbo charging a non turbo 4g63
Old Jul 9, 2008 | 06:23 PM
skellagher's Avatar
Default turbo charging a non turbo 4g63
ok well in my previous thread i was explaining that my 4g63t is blown up so i need a cheap fix just for a few months so my idea is i want to buy a non turbo 4g63 and put my turbo and the turbo ecu on the non turbo so i guess what i am getting to here is i need an educated answer on what would my results be? i understand the non turbo runs like 9:1 compression i just wanna know if i will make the same if not better power than with the turbo motor. i will be running something like 10-12 lbs of boost but like i said i only need that motor until tax time. thank you guys once again. another thing is there any difference between the turbo and non turbo intake manifold i understand i will be needing the turbo injectors and all that good stuff
Old Jul 9, 2008 | 06:39 PM
dsm1990gsx's Avatar
Default RE: turbo charging a non turbo 4g63
If you run 10-12 lbs of boost you will do damage to the pistons. If you want a temp repair, put the non turbo bottom end in and run 8lbs of boost untill you have your turbo bottom end ready to go back in. As for powerI would imagine it wouldbe similar to a stockauto turbo 1g.
Non turbo/turbo differences- turbo, i/c, i/c piping, harness, injectors, regulator, resistor pack, ecu, maf, knock sensor, coolant feed to turbo, throttle body, pistons, cams, oil squirters, clutch, flywheel, exhaust manifold, downpipe, intake manifold,I think thats most of it.
Old Jul 11, 2008 | 07:01 AM
it is a complete waste of time and money to bother with a non turbo engine. You can find a 4g63 turbo motor all over the internet and junk yards incredibly cheap. So why even waste the time
And what exactly happened to your motor. Because "blown up" tells me nothing.
GermanEclipse
Nov 19, 2006 01:51 PM
WhiteTrash93
Sep 10, 2006 11:37 AM
micahman
May 4, 2006 04:48 PM
926bolt4g63talonnt
Jul 9, 2005 04:44 PM
fst2qtrmile
Jan 9, 2005 07:24 PM
