*UPDATED*oil pan leak
Old Jun 9, 2007 | 08:17 AM
lycan84's Avatar
Default *UPDATED*oil pan leak
can a oil pan leak be fixed with something like jb weld just for the time being until i can get a oil pan. it is damaged. not sure how bad never been underneath of it. and if i can use jb weld do i have to pull the pan off?
Old Jun 9, 2007 | 08:31 AM
tjbiker031's Avatar
Default RE: oil pan leak
where is the leak comming from? the seal? crack in the pan? drain plug? if its the oil pan gasket, spend the 5 bucks for the gasket from autozone and it will take you 4 or 5 qts of oil and 20 tops to drain the oil, pull off the pan, clean up the gasket area, put the new gasket back on, torque down the bolts to spec! and put new oil in.
Old Jun 9, 2007 | 02:09 PM
I Drive Naked's Avatar
Depending on if the pans cracked, how big of a crack it is, then yes... an oil pan can be JB welded.
I did it myself on a friends Saturn.
He never replaced the pan and its now been over a year.
Old Jun 10, 2007 | 02:17 AM
lycan84's Avatar
the seller told me that the pan its self is damaged. i need to crawl underneath her one day and see what the prob really is maybe ill use a tampon and plug the hole. lmao.
josh did you pull the pan to jb it . thats my main concern is having to pull it off to jbweld it.
Old Jun 10, 2007 | 06:40 AM
lycan84's Avatar
Old Jun 10, 2007 | 10:02 AM
tjbiker031's Avatar
um yeah i would pull the pan off and clean off the oil so you dont catch your engine on fire
Old Jun 10, 2007 | 02:12 PM
No, I left the pan on.
If you're gonna pull it, might as well replace it.
I just drained the oil and let it sit a while, cleaned it off, the rigged it. lol
Old Jun 10, 2007 | 02:27 PM
tjbiker031's Avatar
a little dangerous but it works lol
Old Jun 13, 2007 | 02:32 AM
lycan84's Avatar
how is this dangerous isnt it just a compound
Old Jun 13, 2007 | 01:10 PM
sk8dudety's Avatar
why would you replace the oil pan if you can just do a simple jb weld fix?? taking an oil pan off is cake... just let the car sit, drain the oil, unbold it and pull it down... clean it, fix it, bolt it back up, and put new oil in it
