120k miles
My 96 GSX is approaching 120k and I was just wondering what I should do, like what parts I should buy, and all that. I'm doing all the stuff with the timing belt and water pump, and I was just wondering if there is anything else that I should get. I was just wondering also what that balance shaft remover does.
all the balance shaft does is make the engine a little more stable at idle, its not a neccessary part of the engine and if you can live with a rough idle then removing it will give you a little more power and torque cause its one less pully the engine has to turn. if ur gonna be doin a lot of work and wanna throw the money down also a new set of timing gears, underdrive pullys and maybe a new cam. or if you wanna go all out just overhaul the whole damn engine. ive also heard good things about powder coating the pistons, rods, intake manifold, etc......
I would suggest that when you do the timing belt, get a AEM cam gear put in and like 1398spdr suggests, pulley kits will help boost extra horsepower. Maybe check your suspension unless you have already changed it or lowered your car.
Unsullied_Spy
03-01-2012 07:42 PM
