120k miles
Old Sep 1, 2004 | 06:57 PM
nate5023's Avatar
Default 120k miles
My 96 GSX is approaching 120k and I was just wondering what I should do, like what parts I should buy, and all that. I'm doing all the stuff with the timing belt and water pump, and I was just wondering if there is anything else that I should get. I was just wondering also what that balance shaft remover does.
Old Sep 1, 2004 | 08:53 PM
1398spdr's Avatar
Default RE: 120k miles
all the balance shaft does is make the engine a little more stable at idle, its not a neccessary part of the engine and if you can live with a rough idle then removing it will give you a little more power and torque cause its one less pully the engine has to turn. if ur gonna be doin a lot of work and wanna throw the money down also a new set of timing gears, underdrive pullys and maybe a new cam. or if you wanna go all out just overhaul the whole damn engine. ive also heard good things about powder coating the pistons, rods, intake manifold, etc......
Old Sep 3, 2004 | 02:58 AM
FatalJRA's Avatar
I would suggest that when you do the timing belt, get a AEM cam gear put in and like 1398spdr suggests, pulley kits will help boost extra horsepower. Maybe check your suspension unless you have already changed it or lowered your car.
Unsullied_Spy
Mar 1, 2012 07:42 PM
ShortyRider
Jan 25, 2012 07:59 PM
drachemorder
Mar 12, 2005 01:34 AM
blackeclipseGT
Aug 11, 2004 11:37 AM
red99spyderGS
Jul 7, 2003 01:48 AM
