15 lbs of boost with out boost controler
Old Dec 24, 2006 | 05:14 PM
anko_kun's Avatar
Default 15 lbs of boost with out boost controler
as far as i know this is not normal but the car still runs fine and fast all ive got is a cat back , intakeand a tubeing kit i have put 3 diff boost gauges on it to check and some times when its cold it hits 16 psi what do yall think
Old Dec 24, 2006 | 05:16 PM
paintballproam's Avatar
Default RE: 15 lbs of boost with out boost controler
stock turbo? BSC removed? maybe the vacume lines are bad, like maybe it got hot and melted together a little and made it more restrictive
Old Dec 24, 2006 | 06:22 PM
anko_kun's Avatar
no bcs romoved and a stock turbo ill the lines are good car as far as i know has never got hot at all
Old Dec 24, 2006 | 06:24 PM
my guess would be a problem with the waste gate, but hey 15psi is safe so have fun.
Old Dec 24, 2006 | 06:47 PM
TheAdvocate's Avatar
Ya sounds like the wastegate.. My friends GSX did that on a 14b turbo, and his was hittin 20 psi if he got on it.. Once he got a new wastegate it was runnin back down around 12...
Old Dec 24, 2006 | 07:02 PM
cold weather will also do that and add exhaust and that will as well. My car went from 1.15 bars to 1.3 bars with only adding exhaust to my car
Old Dec 24, 2006 | 07:09 PM
anko_kun's Avatar
it could be the exhaust i did not have a boost gauge tll after the exhaust got on so
Old Dec 24, 2006 | 07:23 PM
silvercoupe97's Avatar
ORIGINAL: anko_kun
If the bcs is still attached, then it may have had the restrictor removed and with the exhaust and cold weather, it can happen. Check and listen for exhaust leaks if you're really worried about running 15psi. I hope you're turbo timing your car too, that poor T25 is probably getting bright, bright red.
Old Dec 24, 2006 | 07:48 PM
anko_kun's Avatar
it still has restrictor the car had zero mods when i got it and i never removed it ya i got a timer im not 2 woried and there are no exhaust leaks
2slow
May 16, 2007 03:43 PM
jdm2ner
Apr 22, 2006 08:30 PM
GARYMITSU
Jan 31, 2006 05:29 PM
1998blackgst 240
Jun 8, 2005 04:44 PM
GARYMITSU
Mar 21, 2005 09:12 AM
