16G turbo with MBC
Old Jun 25, 2006 | 02:06 PM
agallardo's Avatar
Default 16G turbo with MBC
Hey guys. I think my manual boost controller is set up wrong. I have a t-fitting off the BOV to the MBC and the other side connected off the wastegate actuator. Is this right? But then again, I was looking under vfaq.com and it says that I have to Disconnect the hose connected off the intake (the little skinny one on the side of the radiator). Is this true, because I have mine connected. It says that I have to plug up that nipple off the intake and the Wastegate Solenoid. So in other words, I dont need that hose. Is this right?
http://www.vfaq.com/index-main.html
Old Jun 25, 2006 | 05:25 PM
agallardo's Avatar
Default RE: 16G turbo with MBC
anyone know if I have my MBC connected wrong?
Old Jun 25, 2006 | 08:29 PM
yea you do have to remove that hose and plug off the intake.
Old Jun 26, 2006 | 12:15 AM
agallardo's Avatar
Do you think this is my problem? Do you think this is why I cant adjust my MBC?
Old Jun 26, 2006 | 09:25 AM
probably. That hose that comes off the intake goes to the turbo correct?
Old Jun 26, 2006 | 12:42 PM
agallardo's Avatar
i dont think so. I think it comes off completely. Right? how would it connect to the turbo? Is that what you think?
This is what it says on vfaq.com:
Pull your coolant resevoir straight up (large white container
half-full of fluid), and stick it somewhere out of the way.
Now with the airbox removed you'll have the same view as in the picture above.
Unhook both of the blue hoses from the Wastegate Solenoid (in red).
Unhook the one blue hose going to the intake pipe and plug the nipple
that is left sticking out of the intake (under the yellow "X"), with
one of the rubber stoppers included in your Hallman kit.
I guess I do have to unplug that hose from the intake and plug up that nipple and I guess leave that hose disconnected from the intake but still connected to the wastegate solenoid. In other words I still have to leave that hose connected to the wastegate solenoid but the other end of that hose disconnected.
Is this right?
Old Jun 26, 2006 | 11:14 PM
agallardo's Avatar
anyone know?
Old Jun 27, 2006 | 12:22 AM
93eclipsegsx's Avatar
http://www.plymouthlaser.com/joep.htm
heres how its done on a 1g, hope it helps.
Old Jun 27, 2006 | 01:26 AM
agallardo's Avatar
Thanks man. I guess it helps me out a little. Do you know another website for the 2g Eclipse?
Old Jun 27, 2006 | 04:30 PM
agallardo's Avatar
I guess I am going to plug up the intake hole and the wastegate solenoid. Is this a good idea?
