16G Upgrade
RE: 16G Upgrade
None besides the basics, liike intake, fuel, turbo back exhaust and also porting the o2 housing and manifold but you may not have to my friend didn't on his and it ran fine, also bc, BOV, and you willneed the kit. Also what kind of 16g are you getting, if you get the EVOIII or the big 16g you would probably want 660's so that you can crank up the boost.
RE: 16G Upgrade
if you go with the evo 3 it is a direct bolt on but i would do a little modifycation and crank the bost up to 20 pounds mine runs 25 pounds with denso 660 injectoss and a walbro 255 fuel pump you have to do a little modifycation to the engin to run this but i found it worth it my gsx runs 11.5 in the quartermile i'me planning on swaping to a forced performance fp 3065 soon.
elevate spyder gst
05-13-2009 08:32 AM
