1996 eclipse gs Over Heating
96 eclipse 2.0 non turbo over heating problem.... ive taken the thermostat out and still it over heats.. ive replaced the thermostat housing gasket also... i can start the car and the heat gauge will be in the middle but when i drive it for about 5 minutes it will start to climb till it reaches the top... im also getting no heat inside.... both my radiator hoses are hot so i know its flowing through them... i can see a bunch of water coming out the thermostat housing where the gasket is even tho the gasket is brand new... could i have a bad housing? im really hoping its not the water pump... all advice is appreciated
1996, 96, 98, eclipse, forum, gs, heat, housing, intermittent, location, mitsubishi, overheating, pump, spyder, thermostat, water
