1997 Eclipse spyder running on 2 cylinders
Old Oct 12, 2010 | 05:15 PM
97EclipseSpyder's Avatar
Default 1997 Eclipse spyder running on 2 cylinders
I have a 1997 eclipse spyder that i replaced the engine in.After finished it only ran on 2 cylinders. then i replaced the camshaft position sensor and crankshaft position sensor and it still ran on 2 cylinders. all 4 have spark and the 2 that fire (cylinders 3 and 4) have fuel. but when i switch 2 and 3 fuel injector wires then the 2 that fire are 2 and 4. so i thought it was something electrical so i replaced the ecu. no difference. When i bought the engine it had the distributer not the coil pack like mine.so a dealer said i had to get this piece called a cam position cylinder (ever heard of it?). i put it in before replacing everything else.is there a difference between the 2.0 cam position cylinder and the 2.4 like mine. What else can it be?
Old Oct 13, 2010 | 01:44 AM
KaiserEclipse's Avatar
check your fuel injectors perhaps if it fires the other pistons when you switch the wires, is it throwing a code?
Old Oct 13, 2010 | 04:08 PM
yea the code i get is telling me the camshaft position sensor but i already replaced that..when i disconnect the sensor it fires on all 4 but extremly rough
jfed256
1st Generation
Oct 10, 2010 10:14 PM
davidmitsusrock
Nov 3, 2006 01:09 AM
astraldweller
Nov 8, 2005 12:20 PM
CarNewb
1st Generation
Jun 30, 2005 03:41 PM
johnnybowen
May 29, 2005 06:13 PM
