1997 non tubro Eclipse problem
Old Jul 30, 2008 | 09:11 AM
sbramlett's Avatar
Default 1997 non tubro Eclipse problem
OK. I have a 1997 Non-turbo Eclipse, That stalls. gives no codes, fuel pressure stays on 50psi. good spark.
when it runs it runs perfect. then it will stall and is a pain to start afterwards. once it starts runs perfect intill it stalls again.
sometimes in will stall again in 2 mins or it could be 20 mins. Checked spark plugs, fuel pressure, codes, everything checks out.
the thing is to get it to start again i will remove the plug to the MAP sensor and it will start. the next time i wont.
and I can remove the plug to the idle control moter and it starts. its not always the same sensor but its always one of those two.
But it does not give a code.
Please help
Scott
Old Jul 30, 2008 | 01:26 PM
gmarc68's Avatar
Default RE: 1997 non tubro Eclipse problem
i had similar problems and it turned out to be my starter realy. there located above your clutch fuel i think
Old Jul 30, 2008 | 02:55 PM
OH DEAR GOD what is that thing? ^
Old Jul 30, 2008 | 05:55 PM
dsm1990gsx's Avatar
ORIGINAL: gmarc68
What?
Old Jul 30, 2008 | 06:13 PM
estraw's Avatar
ORIGINAL: gmarc68
your starter relay will not cause your car to stall. and wtf is clutch fuel?
take your car to autozone and get your alternator checked. they should do it for free
and also make sure your battery terminals have a good connection
Old Jul 30, 2008 | 06:47 PM
sbramlett's Avatar
thanks for the answers, I was wondering what clutch fuel is also.....LOL
alternator is working good and batt. cables are clean
Scott
Old Jul 31, 2008 | 10:30 AM
gmarc68's Avatar
lol i meant oil. and its not the starter that will make it stall. but turning on part was wat mine was, it was just burnt out.
Old Jul 31, 2008 | 07:59 PM
757eclipse's Avatar
i have the same problem. i have an auto transmission but whenever i stop i just throw it in neutral and it works for me but i don't no about your tranny
LaNiceGuy
1st Generation
Feb 13, 2016 06:37 PM
redline_racing
Dec 23, 2010 07:52 PM
hoser33b
Mar 21, 2010 10:34 AM
Edelbrock
May 16, 2008 07:45 AM
Bonezz
Nov 25, 2005 03:37 PM
