2 questions
Old Oct 15, 2004 | 08:06 PM
99eclipseguy's Avatar
Default 2 questions
I just got my AEM cold air intake and there are two little pipes coming out the sides. If I am correct, one goes into the throttle body but I dont know where the other one goes. I thought I was missing some hoses but I am not. Whats the extra pipe for? The second one is, my pulley is squeeling a lot so I went and bought a new unorthodox crank pulley. My step dad is telling me that its my bearing that is making the noise and that I need to replace that. Was I wrong by buying the pulley and only having to replace the bearing and if I do, does anyone know a website or store where I can get one?
Old Oct 16, 2004 | 02:07 PM
1398spdr's Avatar
Default RE: 2 questions
the second hookup is for the exahust return line from the valve cover to recirculate the unused air back through the intake system, i would suggest getting a filter system as this air is very dirty and oily before you hook it back up........... as for the bearing im not sure........
Old Oct 19, 2004 | 11:41 PM
GReddyGST's Avatar
just take a look at ur stock air system...then compare it...also chck to see how it applies to ur car...AEM might want you to just plug it...you never know.....but im sure 1898spdr is right...
Old Oct 20, 2004 | 12:51 PM
SpyderGS's Avatar
1398 is right, and the filter setup he's talking about is called a catch can. You don't need to plumb in that line, you can put a breather filter on the valve cover to vetilate the system, but the filter will prevent oil from squirting out at sudden high pressures. The catch can is one step further. It's basically a a can that the oil can go into if the breather filter ever gets too clogged. Greddy sells them, as do Apexi and HK$. You're step-dad may be right, but the only way to know for sure is to put on the new pulley, tighten everything up and see if it still makes noise.
JazAddict
Nov 23, 2021 03:05 AM
nate5023
Aug 22, 2004 01:17 PM
mb7
Jul 9, 2004 04:05 PM
spyder-man
Jun 21, 2004 02:06 PM
Drykan
May 25, 2004 02:55 AM
