2 questions about fuel
Old Nov 30, 2007 | 02:45 PM
98gstspy's Avatar
Default 2 questions about fuel
#1. dose anybody have any good recomendations on where to get a nice set of 660cc injectors that are decently price?
#2 i have a stock turbo wat kind of a/f ratio should i have? and how much psi can i run on stock without hurting anything(i am in the process of hooking up my AEM boost controler, just trying to c what kind of power i can make out of the stock turbo for now)?
Old Nov 30, 2007 | 03:15 PM
Natedogg89's Avatar
Default RE: 2 questions about fuel
1) Cant help you there
2) Dont run any more than 14-15 PSI at the MAX on the stock T-25 with stock fuel.. Stock boost is about 10-12 so you wont see that much more at 15 for power
Old Nov 30, 2007 | 03:28 PM
Your ratio should be around 11.5. Remember, the higher, the leaner, and the lower, the richer.
You could prolly get like 250hp out of the stock turbo. Thats about it.
As for the injectors, look on dsm tuners.com or dsmsource for used stuff. If you want brand new then go to slowboyracing.com or buschurracing.com or amsperformance.com, maybe even extremepsi.com has them (not sure)
Good luck.
Old Nov 30, 2007 | 04:37 PM
TheAdvocate's Avatar
I personally deal with extremepsi, and have had good products and fast delivery..
Old Nov 30, 2007 | 07:22 PM
dorian7's Avatar
I have this set up: Dave brode upper IC pipe, 2.5" magnaflow exhaust, K&N filtercharger and intake, AEM tru boost, 1g BOV, ACT2600 clutch and streetlite flywheel I run 16 to 17 PSI on the stock turbo perfectly fine anymore than that you will need upgrades.
Old Nov 30, 2007 | 07:29 PM
GReddyGST's Avatar
the most youll stabilize is around 15psi... I ran somewhere up to 21 by accident just messing with my boost controller, but it would just spike and return to 13-15 (its not good for the turbo though to be higher then 15)
Old Nov 30, 2007 | 07:54 PM
98gstspy's Avatar
WHAT IS THEPERFECT A/F RATIO ?
Old Nov 30, 2007 | 08:24 PM
dorian7's Avatar
I run 16-17 stabelized and it works great.
Old Dec 1, 2007 | 01:09 AM
ARE YOU SERIOUS??? Thats for a n/a car!
Old Dec 1, 2007 | 01:33 AM
dorian7's Avatar
huh?
