2 questions about fuel
Old Dec 1, 2007 | 03:32 AM
Natedogg89's Avatar
Default RE: 2 questions about fuel
Yeah i'm lost seb
Old Dec 1, 2007 | 08:42 AM
_Adrian_'s Avatar
ORIGINAL: dorian7
I run 16-17 stabelized and it works great.
thats far tooo lean ... your bound to melt something and im just having a hard time seeing how you makin power [&:]
a safe range for turbo cars is between 13-11.5 if your in the low 11's you overfueling for an inneficient IC or a maxed out turbo that works past its efficiency range and instead of compressing the air also overheats it!
been down that road an it just not worth it. if its in the case of the turbo ... time to upgrade to something a bit more efficient
Old Dec 1, 2007 | 12:11 PM
I just realized he meant boost... whoops lol
Old Dec 1, 2007 | 01:18 PM
98gstspy's Avatar
for 660 cc injectors should i go with a 255lph fuel pump or the 190lph one cuz they both cost the same?
Old Dec 1, 2007 | 02:20 PM
The 190 is fine. The only problem with the 255 is that you need an aftermarket fuel pressure regulator. So, it does end up being a little more.
foetus envy
Oct 14, 2008 04:38 PM
jerusry
May 27, 2008 08:04 PM
Evo2nv
Jan 23, 2008 08:51 PM
Evo2nv
Jan 22, 2008 03:02 PM
kobalt
Mar 17, 2006 07:19 PM
