2g turbo question
Old Feb 23, 2004 | 02:13 PM
Pinser555's Avatar
Default 2g turbo question
I was told that if you plug the 2 ends of the pipe leading from the turbo into the intake, it may increase you boosta LITTLE, and give you a louder blow off.Is this true?<IMG src=uploads/Pinser555/8377B_Engine.JPG border="0"></P><edited><editID>Pinser555</editID><editDate>38040.5143981481</editDate></edited>
Old Feb 23, 2004 | 03:23 PM
BurntGSX's Avatar
that would be your BOV recirculation. its good to not have if you are running any mods, cause when your BOV expells the pressurized air back to your intake, your computer will go "WTF??" cause it just got this huge shot of cold condensed air and its not used to it. best bet would be a boost controller and gauge. CHEAP. turboXS manual boost controller, you can pick one up for around 80 and guages go anywhere from 40-250+ depending on brand preference. as far as more boost... I think MORE steady boost is a yes. and your BOV will release to atmosphere and sound a lot louder
Old Feb 23, 2004 | 03:26 PM
Pinser555's Avatar
I did buy a manual boost controller the other day, and waiting for cash to get a good gauge.But i was under the impressio that the stock BOV will leak if I bump up the pressure 2-3 pounds?</P>
Old Feb 23, 2004 | 03:35 PM
BurntGSX's Avatar
I didn't have a prob with mine, but I did upgrade soon after to HKS SS and new innercooler pipe. that was about $500 brand new. but it sounds NICE. otherwise, find a 1st gen BOV. I know a lot of 2nd gen owners running them. they hold pressure better.
Old Feb 24, 2004 | 01:48 PM
SpyderGS's Avatar
Yeah, burntgsx is right, do not disconnect this. Back in the day, a lot of people used to try this mod and didn't have good results(in a stock car). At wot the car will run fine, but if you let off the throttle too quickly, the car will stall out. Some people thought that they could just let off the throttle easy and avoid this problem, but it will sometimes just stall outeven then. The best way to vent to the atm is to eliminate the maf sensor and run a map like a vpc. But that costs a lotta money. Not worth it just to get a better sound.
oasis
Jan 23, 2005 05:43 PM
override1059
Feb 10, 2004 09:37 PM
Som1Dies2Nite
Dec 1, 2003 08:47 PM
2fast4u
Sep 6, 2003 06:44 PM
kdombrovski
Jul 2, 2003 01:00 AM
